electron-rebuild and MagicMirror v2.18 (and more)
@sdetweil Hi, i did a fresh install and added the module manually. I do not use MMM-PIR-Sensor but some other users had the same problem with MMM-Gestures (which i do not use either). Did a clean install of MagicMirror on a development Pi with your script and added modules manually.
K karsten13 referenced this topic on
Awesome. It really works. I had the same issue and it was really frustrating, until i stumbled upon this solution. Great my PIR-sensor module was revived. I just followed the steps mentioned and voila…it has come back to life. Thanks a ton, it is selfless gentlemen like yourself who keep this world going. Kudos.
Hoping someone can help. Having the same issue with MMM-Reddit since updating to MM v2.20.0 . Spent a couple days scouring this as well as other forums for a fix. I already tried everything from this thread. Still getting the error below, no matter what I try. Any help would be greatly appreciated.
- MM v2.20.0
- Node v16.17.1
-Node-gyp v9.2.0
-NPM v8.15.0
This is the code I get for any rebuild or npm install…etc:
npm ERR! code 1
npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
npm ERR! command failed
npm ERR! command sh /tmp/postinstall-fdc6f405.sh
npm ERR! Building: /usr/bin/node /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp verb cli [
npm ERR! gyp verb cli ‘/usr/bin/node’,
npm ERR! gyp verb cli ‘/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js’,
npm ERR! gyp verb cli ‘rebuild’,
npm ERR! gyp verb cli ‘–verbose’,
npm ERR! gyp verb cli ‘–libsass_ext=’,
npm ERR! gyp verb cli ‘–libsass_cflags=’,
npm ERR! gyp verb cli ‘–libsass_ldflags=’,
npm ERR! gyp verb cli ‘–libsass_library=’
npm ERR! gyp verb cli ]
npm ERR! gyp info using [email protected]
npm ERR! gyp info using [email protected] | linux | arm
npm ERR! gyp verb command rebuild []
npm ERR! gyp verb command clean []
npm ERR! gyp verb clean removing “build” directory
npm ERR! gyp verb command configure []
npm ERR! gyp verb check python checking for Python executable “python2” in the PATH
npm ERR! gyp verbwhich
failed Error: not found: python2
failed at getNotFoundError (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:13:12)
failed at F (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:68:19)
failed at E (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:80:29)
failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:89:16
failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/index.js:42:5
failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/mode.js:8:5
failed at FSReqCallback.oncomplete (node:fs:206:21)
failed python2 Error: not found: python2
failed at FSReqCallback.oncomplete (node:fs:206:21) {
failed code: ‘ENOENT’
failed }
npm ERR! gyp verb check python checking for Python executable “python” in the PATH
succeeded python /usr/bin/python
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Command failed: /usr/bin/python -c import sys; print “%s.%s.%s” % sys.version_info[:3];
npm ERR! gyp ERR! stack File “”, line 1
npm ERR! gyp ERR! stack import sys; print “%s.%s.%s” % sys.version_info[:3];
npm ERR! gyp ERR! stack ^
npm ERR! gyp ERR! stack SyntaxError: invalid syntax
npm ERR! gyp ERR! stack at ChildProcess.exithandler (node:child_process:400:12)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack at maybeClose (node:internal/child_process:1093:16)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
npm ERR! gyp ERR! System Linux 5.15.61-v7l+
npm ERR! gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–verbose” “–libsass_ext=” “–libsass_cflags=” “–libsass_ldflags=” “–libsass_library=”
npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
npm ERR! gyp ERR! node -v v16.17.1
npm ERR! gyp ERR! node-gyp -v v3.8.0
npm ERR! gyp ERR! not ok
npm ERR! Build failed with error code: 1npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2022-10-07T02_52_13_196Z-debug-0.log -
@Dresch360 said in electron-rebuild and MagicMirror v2.18 (and more):
npm ERR! gyp verb which failed Error: not found: python2looks like u don’t have python version 2 installed
do python -v
@sdetweil Thanks Sam! Ughh…I feel pretty silly that I didn’t realize that. Was looking at the least obvious issue. Works perfectly after installing Python 2. Thanks again!
@bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
npm i magicmirror-rebuild
Thank you very much :-)
it works for me with another module “MMM-Buttons”, I’m so happy!
do you have to runnpm i magicmirror-rebuild
every time in each module folder? -
@Lusbueb
Usually, No.
Only the magic mirror module which use “native node module” needs it. but it would be hard to distinguish by a normal user. -
L Lusbueb referenced this topic on
