    frameless mirror
    Scheduled Pinned Locked Moved Show your Mirror
    17 Posts 9 Posters 19.8k Views 8 Watching
    • prototype0815P Offline
      prototype0815
      Nice Mirror Bangee, where did you baught it? What is the thickness of these mirrors?
      Kind regards from Germany
      • BangeeB Offline
        Bangee Module Developer
        I did it by my self.
        The glass is a 4mm two way mirror and the frame is aluminium 1.5 mm.
        and the complete mirror is about 5 cm thick
        • P Offline
          PaulB
          @Bangee
          Your Mirror looks awesome. Which components did you used to built the Mirrorframe and furthermore, how did you manage that the mirror is fixed on the Display?
          Kind regards from Bayreuth, Germany.
          Paul B
          • BangeeB Offline
            Hi @PaulB
            I’ve used an aluminium sheet, 1.5 mm thik. I made a sketch and went to a Sheet metal processing company.
            But the coast are very high. :-)
            The fixing is included in to the mirrorframe and its built in one pice of aluminium.
            Bangee
            • P Offline
              PaulB
              @Bangee Your mirror looks so well, but I think I am going with a frame made out of wood for my first attempt. Nevertheless I am very interested in your mirror project, and still looking for a way to rebuild it with wood.
              • BangeeB Offline
                Here is my latest project. I have integrated the PIR sensor in my the glass 😏
                binderthB A 2 Replies Last reply Reply Quote 5
                • binderthB Offline
                  binderth @Bangee
                  @Bangee that Looks so great!
                  I’m looking into planning my frame at the moment. How do you attach the Monitor to the mirror and how do you place it on the wall, could you please add some information/pictures on that?
                  Thanks!
                  • BangeeB Offline
                    Hi @binderth
                    The monitor is put in the frame and hold by the glass and some lashes.
                    This frame very thin an built with 1.5mm aluminium.
                    The Weight ist only 1 kg.
                    I’ve used a 3mm 12% twoway mirror.
                    If someone is interested in this, I will produce some more pices.
                    PM me if you’re interested in it.
                    • P Offline
                      PindaPower
                      Looking great, hope you get the PIR working.
                      I will appreciate if you share you work(step) to your finishing mirror. Trying to upgrade my mirror with PIR sensor in the future. So your step/choice would help me later on.
                      • K Offline
                        KrawallKurt
                        Wow… I was actually thinking of getting a 3% mirror. Will rethink that. What display are you using? Is it a 250cd/m² one?
