    new update/upgrade script, ready for testing
    Scheduled Pinned Locked Moved General Discussion
    325 Posts 26 Posters 512.7k Views 23 Watching
      sdetweil @bdream
      @bdream something is wrong, 122 restarts 0 uptime.
      do
      pm2 stop 0
      pm2 logs --lines=100
        bdream
        here is
        pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
        [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/pm2.log last 100 lines:
        PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
        PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
        PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
        PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
        PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
        0|MagicMir |
        0|MagicMir | > [email protected] start /home/pi/MagicMirror
        0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        0|MagicMir |
        0|MagicMir |
        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
        0|MagicMir | npm ERR! errno ENOENT
        0|MagicMir | npm ERR! [email protected] start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
        0|MagicMir | npm ERR! spawn ENOENT
        0|MagicMir | npm ERR! Failed at the [email protected] start script.
        0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        0|MagicMir |
        0|MagicMir | npm ERR! A complete log of this run can be found in:
        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
        0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
        0|MagicMir | npm ERR! code ELIFECYCLE
        0|MagicMir | npm ERR! syscall spawn
        0|MagicMir | npm ERR! file sh
        0|MagicMir |
        0|MagicMir |
        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
        cheers, bdream
          sdetweil @bdream
          @bdream hm. looks like my upgrade script failed to restore the start script change
          edit package.json
          change the start line to
          "start": "./run-start.sh",
          then
          pm2 flush
          pm2 start 0
          I see the bug, but am on my phone right now and will have to fix it later
            bdream
            @sdetweil it dose not work
            if I change to
            "start": " ./run-start.sh",
            also as
            "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
            I get an web explorer showing an error
            ERR_CONNECTION_REFUSED
            localhos refused connection.
            cheers, bdream
              sdetweil @bdream
              @bdream notice the 1st has a space in front of the ./, I edited that space out
                sdetweil @sdetweil
                @bdream also. let’s try this
                stop everything
                then
                cd ~/MagicMirror
                npm run server
                the server side should start.
                  bdream
                  @sdetweil said in new update/upgrade script, ready for testing:
                  That is also not helpful
                  stop everything
                  How to stop everything?
                  Is this enough?
                  pm2 stop 0
                  cheers, bdream
                    bdream
                    npm run server
                    I get this:
                    pi@RasPiZeroW:~ $ cd MagicMirror/
                    pi@RasPiZeroW:~/MagicMirror $ npm run server
                    > [email protected] server /home/pi/MagicMirror
                    > node ./serveronly
                    internal/modules/cjs/loader.js:638
                        throw err;
                    Error: Cannot find module 'proxy-addr'
                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                        at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                        at Module.require (internal/modules/cjs/loader.js:692:17)
                        at require (internal/modules/cjs/helpers.js:25:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                        at Module._compile (internal/modules/cjs/loader.js:778:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                        at Module.load (internal/modules/cjs/loader.js:653:32)
                        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                    npm ERR! errno 1
                    npm ERR! [email protected] server: `node ./serveronly`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the [email protected] server script.
                    npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
                    cheers, bdream
                      sdetweil @bdream
                      @bdream I have opened issue
                      https://github.com/MichMich/MagicMirror/issues/2069
                      I cannot debug more myself at this time. in hospital, sorry
                      chrisparkerC 1 Reply Last reply Reply Quote 0
                        bdream
                        @sdetweil Sam! You are in hospital :face_with_head-bandage:
                        So you have to focus on yourself!
                        Wish you all the best and fast recovery!
                        Hope you are back soon!
                        cheers, bdream
                        • 27
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 29 / 33
