    new update/upgrade script, ready for testing
    Scheduled Pinned Locked Moved General Discussion
    325 Posts 26 Posters 520.4k Views 23 Watching
      bdream
      @sdetweil it dose not work
      if I change to
      "start": " ./run-start.sh",
      also as
      "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
      I get an web explorer showing an error
      ERR_CONNECTION_REFUSED
      localhos refused connection.
      cheers, bdream
        sdetweil @bdream
        @bdream notice the 1st has a space in front of the ./, I edited that space out
          sdetweil @sdetweil
          @bdream also. let’s try this
          stop everything
          then
          cd ~/MagicMirror
          npm run server
          the server side should start.
            bdream
            @sdetweil said in new update/upgrade script, ready for testing:
            That is also not helpful
            stop everything
            How to stop everything?
            Is this enough?
            pm2 stop 0
            cheers, bdream
              bdream
              npm run server
              I get this:
              pi@RasPiZeroW:~ $ cd MagicMirror/
              pi@RasPiZeroW:~/MagicMirror $ npm run server
              > [email protected] server /home/pi/MagicMirror
              > node ./serveronly
              internal/modules/cjs/loader.js:638
                  throw err;
              Error: Cannot find module 'proxy-addr'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                  at Module.require (internal/modules/cjs/loader.js:692:17)
                  at require (internal/modules/cjs/helpers.js:25:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                  at Module._compile (internal/modules/cjs/loader.js:778:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                  at Module.load (internal/modules/cjs/loader.js:653:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! [email protected] server: `node ./serveronly`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the [email protected] server script.
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR! A complete log of this run can be found in:
              npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
              cheers, bdream
                sdetweil @bdream
                @bdream I have opened issue
                https://github.com/MichMich/MagicMirror/issues/2069
                I cannot debug more myself at this time. in hospital, sorry
                chrisparkerC 1 Reply Last reply Reply Quote 0
                  bdream
                  @sdetweil Sam! You are in hospital :face_with_head-bandage:
                  So you have to focus on yourself!
                  Wish you all the best and fast recovery!
                  Hope you are back soon!
                  cheers, bdream
                    sdetweil @bdream
                    @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
                      bdream
                      @sdetweil sounds hard to you. far away from your computer.
                      near time you have to walk and walk all will go as before and better.
                      All the best!
                      cheers, bdream
                        sdetweil @bdream
                        @bdream if u rename the mm folder to mm. save and the reinstall does it work?
                        • 27
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 29 / 33
