    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 28.5k Views 26 Watching
      earlman @Guest
      @Sean yup! The reason I messed around with the CSS so much was to make it much more flexible with different screen sizes. I’ll post a screenshot once I get back to my computer
        earlman @Guest
        @Sean i like keeping it pretty minimal right now, but here’s what it looks like in landscape 0_1567030482787_25D7C3A6-B9CA-4000-97FB-A1B08E8810AD.png
          smackenzie5 @earlman
          @earlman
          I’m using the default clock, calendar, current weather, and weather forecast. I’m also using google-route. I’d be interested in anything you could do to make the Google map look better in the route module. I assume you don’t care about the modules that run in the background and don’t show on the screen. Thanks
            A Former User @earlman
            @earlman
            Looks so nice. I want to try yours.
            1 Reply Last reply Reply Quote -1
              earlman
              Project Update (& Installation Instructions)
              @skibro @bachoo786 @Sean @smackenzie5
              Alrighty y’all! Got some great news for those who wanna try this setup out. Heads up though—might take a bit of time to set up,
              so don’t expect to get it looking right in a couple clicks.
              First, I’ve added Pexels support to MMM-Wallpaper (thanks @kolbyjack for the quick response).
              As for everything else, all the instructions for setting it up can be found here
              Though I’ve been doing development work for a while, this is one of my first open-source projects, so I’ll definitely do my best to help you guys out if you need it.
              • lavolp3L Offline
                lavolp3 Module Developer @earlman
                @earlman I have to say I really love the grid concept. I have a monitor sitting in the lower right corner of the mirror and a grid design would look much better.
                Can you share your main.css or is it on GitHub?
                Sorry just saw the latest reply with all the information I needed. Thanks man!!
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  @earlman
                  Thanks for putting this together.
                  Finally had some time to work on this today but got the following error message when running it for the first time:
                  pi@raspberrypi:~ $ cd MagicMirror
                  pi@raspberrypi:~/MagicMirror $ sudo npm start
                  > [email protected] start /home/pi/MagicMirror
                  > sh run-start.sh
                  Starting MagicMirror: v2.7.1
                  Loading config ...
                  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:116
                      				pexels_key: [my API key was here],
                  SyntaxError: Invalid or unexpected token
                      at new Script (vm.js:74:7)
                      at createScript (vm.js:246:10)
                      at Object.runInThisContext (vm.js:298:10)
                      at Module._compile (internal/modules/cjs/loader.js:678:28)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                      at Module.load (internal/modules/cjs/loader.js:620:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                      at Module.require (internal/modules/cjs/loader.js:658:17)
                      at require (internal/modules/cjs/helpers.js:20:18)
                  Loading module helpers ...
                  Initializing new module helper ...
                  Module helper loaded: updatenotification
                  No helper found for module: helloworld.
                  All module helpers loaded.
                  Starting server on port 8080 ...
                  Server started ...
                  Connecting socket for: updatenotification
                  Sockets connected & modules started ...
                  Launching application.
                  Here’s my config.js:
                  			module: "MMM-Wallpaper",
                  			position: "fullscreen_below",
                  			config: { // See "Configuration options" for more information.
                  				source: "pexels",
                      				slideInterval: 60 * 1000, // Change slides every minute
                      				orientation: "vertical",
                      				pexels_search: "beach"
                  Thoughts?
                  Thanks,
                  Scott
                    sdetweil @smackenzie5
                    @smackenzie5 said in Magic Mirror Redesign WIP :D:
                    you need to get a pexels api key and put in where the text says
                      smackenzie5 @sdetweil
                      Yeah, I have the Pexels API key.
                      Replaced it with those words just for the forum post.
                      @earlman
                      BTW - getting the Pexels API key was immediate, no wait
                      Thanks,
                      Scott
                        @smackenzie5 did you put quotes around the key value? If not, that would explain the config error message
                        • 4 / 5
