    325 Posts 26 Posters 500.8k Views 23 Watching
      bdream
      @sdetweil said in new update/upgrade script, ready for testing:
      npm run server
      I get this:
      pi@RasPiZeroW:~ $ cd MagicMirror/
      pi@RasPiZeroW:~/MagicMirror $ npm run server
      > magicmirror@2.12.0 server /home/pi/MagicMirror
      > node ./serveronly
      internal/modules/cjs/loader.js:638
          throw err;
      Error: Cannot find module 'proxy-addr'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 server script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:
      npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
      cheers, bdream
        sdetweil @bdream
        @bdream I have opened issue
        https://github.com/MichMich/MagicMirror/issues/2069
        I cannot debug more myself at this time. in hospital, sorry
        chrisparkerC 1 Reply Last reply Reply Quote 0
          bdream
          @sdetweil Sam! You are in hospital :face_with_head-bandage:
          So you have to focus on yourself!
          Wish you all the best and fast recovery!
          Hope you are back soon!
          cheers, bdream
            sdetweil @bdream
            @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
              bdream
              @sdetweil sounds hard to you. far away from your computer.
              near time you have to walk and walk all will go as before and better.
              All the best!
              cheers, bdream
                sdetweil @bdream
                @bdream if u rename the mm folder to mm. save and the reinstall does it work?
                  sdetweil
                  i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
                  let me know how it goes
                  • chrisparkerC Offline
                    chrisparker @sdetweil
                    @sdetweil Get well soon!
                      ember1205
                      A couple of quick questions…
                      • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
                      • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
                        sdetweil @ember1205
                        @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
                        the update cycle is 90days, 1st of the month
                        if u look at my upgrade-script I check the versions using curl, line 173
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 30 / 33
