    325 Posts 26 Posters 535.0k Views 23 Watching
    • T Offline
      trividar
      Can someone write a how to instruction for mac? Thanks a lot…
        Mykle1 Project Sponsor Module Developer @trividar
        @trividar said in new update/upgrade script, ready for testing:
        How to run the update/upgrade script? :-/
        T 1 Reply Last reply Reply Quote 0
        • T Offline
          trividar @Mykle1
          @Mykle1 sorry for the noob question! I tried it and I got just errors…
            No worries. :thumbsup:
            When did you run it? I’ve just done it minutes ago and it works fine. @sdetweil has been working on it but I believe he has ironed out most, if not all of the kinks.
            1. So, when did you run it?
            2. Errors during the upgrade or after the upgrade?
            3. What were the errors?
            • T Offline
              trividar @Mykle1
              @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
                @trividar
                Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
                • T Offline
                  trividar
                  this is what I get:
                  > cd - >/dev/null
                  > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                  > else
                  > echo It appears MagicMirror has not been installed on this system
                  > echo please run the installer, "raspberry.sh" first
                  > fi
                  Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
                  Mykle1M S 2 Replies Last reply Reply Quote 0
                    @trividar
                    Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
                      sdetweil @trividar
                      @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
                        gonzonia
                        Test runs fine…This is the result when I try to apply the log will be ```
                        code_text
                        No LSB modules are available.
                        doing test run = false
                        update log will be in /home/pi/MagicMirror/installers/upgrade.log
                        saving custom.css
                        upgrading from version 2.9.0 to 2.10.0
                        fetching latest revisions
                        there were merge errors
                        error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
                        you should examine and resolve them
                        using the command git log --oneline --decorate
                        500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
                        restoring custom.css
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 32
                        • 33
                        • 18 / 33
