@BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
Thx for the report
@sdetweil >local version 2.10.1 already same as master 2.10.1
u are upgrading from/to the same version, so no work is done…
if u want to force it to apply changes (again) then use force as the parm
bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
@sdetweil Correct, but isn’t it supposed to run for modules, too?
@BKeyport not if it’s doing nothing
@sdetweil oh, gotcha.
Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
Thanks!
@BKeyport use force. It will do it.
Hi Sam! I run your update script an my Pi0
Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:pm2 restart MagicMirror
looks good
[PM2] Applying action restartProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ ┌─────┬────────────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐ │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │ ├─────┼────────────────┼─────────────┼─────────┼─────────┼──────────┼────────┼──────┼───────────┼──────────┼──────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ default │ 2.12.0 │ fork │ 19770 │ 0s │ 122… │ online │ 0% │ 2.5mb │ pi │ enabled │ └─────┴────────────────┴─────────────┴─────────┴─────────┴──────────┴────────┴──────┴───────────┴──────────┴──────────┴──────────┴──────────┘
what is I’m doing wrong?
Many thanks!!!
here is
pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100 [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 100 lines: PM2 | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT] PM2 | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online : : PM2 | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror PM2 | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0 PM2 | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
/home/pi/.pm2/logs/MagicMirror-out.log last 100 lines: 0|MagicMir | 0|MagicMir | > [email protected] start /home/pi/MagicMirror 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMir | : :
/home/pi/.pm2/logs/MagicMirror-error.log last 100 lines: 0|MagicMir | npm ERR! errno ENOENT 0|MagicMir | npm ERR! [email protected] start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|MagicMir | npm ERR! spawn ENOENT 0|MagicMir | npm ERR! 0|MagicMir | npm ERR! Failed at the [email protected] start script. 0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|MagicMir | 0|MagicMir | npm ERR! A complete log of this run can be found in: 0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log 0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found 0|MagicMir | npm ERR! code ELIFECYCLE 0|MagicMir | npm ERR! syscall spawn 0|MagicMir | npm ERR! file sh 0|MagicMir | npm ERR! errno ENOENT 0|MagicMir | npm ERR! [email protected] start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|MagicMir | npm ERR! spawn ENOENT 0|MagicMir | npm ERR! 0|MagicMir | npm ERR! Failed at the [email protected] start script. 0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|MagicMir | : : 0|MagicMir | 0|MagicMir | npm ERR! A complete log of this run can be found in: 0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
@bdream hm. looks like my upgrade script failed to restore the start script change
edit package.json
change the start line to"start": "./run-start.sh",
then
pm2 flush pm2 start 0
I see the bug, but am on my phone right now and will have to fix it later
