    Help to install MagicMirror
    Scheduled Pinned Locked Moved Solved Tutorials
    6 Posts 3 Posters 8.8k Views 3 Watching
      greda
      Hello,
      I followed the tutorial: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
      I have installed magic but I have error messages.
      I use a Raspberry pi 2 model B
      Who can help me ?
      Thanks you very much.
        greda
        I forgot this information : npm-debug.log
        0 info it worked if it ends with ok
        1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
        2 info using [email protected]
        3 info using [email protected]
        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
        5 info lifecycle [email protected]~prestart: [email protected]
        6 silly lifecycle [email protected]~prestart: no script for prestart, continuing
        7 info lifecycle [email protected]~start: [email protected]
        8 verbose lifecycle [email protected]~start: unsafe-perm in lifecycle true
        9 verbose lifecycle [email protected]~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
        10 verbose lifecycle [email protected]~start: CWD: /home/pi/MagicMirror
        11 silly lifecycle [email protected]~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
        12 info lifecycle [email protected]~start: Failed to exec start script
        13 verbose stack Error: [email protected] start: sh run-start.sh
        13 verbose stack spawn ENOENT
        13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
        13 verbose stack at emitTwo (events.js:106:13)
        13 verbose stack at ChildProcess.emit (events.js:191:7)
        13 verbose stack at maybeClose (internal/child_process.js:891:16)
        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        14 verbose pkgid [email protected]
        15 verbose cwd /home/pi/MagicMirror
        16 error Linux 4.9.40-v7+
        17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
        18 error node v6.11.2
        19 error npm v3.10.10
        20 error file sh
        21 error code ELIFECYCLE
        22 error errno ENOENT
        23 error syscall spawn
        24 error [email protected] start: sh run-start.sh
        24 error spawn ENOENT
        25 error Failed at the [email protected] start script ‘sh run-start.sh’.
        25 error Make sure you have the latest version of node.js and npm installed.
        25 error If you do, this is most likely a problem with the magicmirror package,
        25 error not with npm itself.
        25 error Tell the author that this fails on your system:
        25 error sh run-start.sh
        25 error You can get information on how to open an issue for this project with:
        25 error npm bugs magicmirror
        25 error Or if that isn’t available, you can get their info via:
        25 error npm owner ls magicmirror
        25 error There is likely additional logging output above.
        26 verbose exit [ 1, true ]
          greda
          Hello,
          I resolved all my problems.
          Thank you.
            j.e.f.f Project Sponsor Module Developer @greda
            @greda For the benefit of others who might run into similar problems, can you post what went wrong and what you did to fix it?
              greda
              Hello,
              I had not downloaded the right version of Rasbian. If you want this to work, you need the RASPBIAN version JESSIE WITH DESKTOP
              • 7 Offline
                7even
                Hi!
                I get the same error when using same version of Rasbian.
                Any news how to fix it?
