    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 23.8k Views 18 Watching
    • Sandy2503S Offline
      Sandy2503
      Hi !
      At 2pm i have updated my mirror to Version 2.1.3.
      but now i can`t access the Mirror from my Home PC.
      /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
      var config =
              port: 8081,
              electronOptions: {
              ipWhitelist: [
                      "127.0.0.1",
                      "::ffff:127.0.0.1",
                      "::1",
                      "192.168.178.20/24"
              language: "de",
              modules: [
                              module: "alert",
      In Mirror Version 2.1.2 it works very well.
      Is the ipWhitelist wrong ?
      I`d like to get access from my whole network after the router like 192.168.178.x --> End
      Sandy2503
      randomnoiseR 1 Reply Last reply Reply Quote 0
        d3r
        Had the same issue. added
        address:"0.0.0.0",
        to the config and it’s working again.
        https://github.com/MichMich/MagicMirror/issues/1036
        randomnoiseR 1 Reply Last reply Reply Quote 2
        • randomnoiseR Offline
          randomnoise @Sandy2503
          @Sandy2503
          Me too… my old WL settings don’t work & also using a blank whitelist (which the update description says should allow all hosts) also doesn’t work.
          Should the font also look different? I realise the Roboto font was ‘moved’ but should it still apply (or do I have to define it in CSS?)
            gshimself
            Yea, same here
            • Hein-JanH Offline
              Hein-Jan
              Same problem here. ipWhitelist worked in 2.1.2. 2.1.3. no more.
              VNC works, Putty works. MMM-Remote-Control cannot be accessed.
              Hein-Jan
              • MichMichM Offline
                MichMich Admin
                Hmm … that doesn’t sound good. Could one of you open an issue on https://github.com/MichMich/MagicMirror/issues?
                Make sure you fill in ALL te questions in the issue template.
                Thanks!
                  d3r
                  address:"0.0.0.0",
                  • MichMichM Offline
                    MichMich Admin
                    Thanks d3r!
                      roramirez Core Contributors
                      That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
                      Easy module development with MagicMirror Module Template
                      Sandy2503S foxF 2 Replies Last reply Reply Quote 0
                        Sandy2503 @roramirez
                        @roramirez - and how can i now access to my mirror from my homenetwork ?
                        What do i have to do ???
                        Sandy
                          randomnoise @d3r
                          @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
                          address:“0.0.0.0”,
                          Thanks d3r, this was indeed the solution.
                          foxF 1 Reply Last reply Reply Quote 1
                          • 4 / 4
