    PIR sensor behind glass?
    65 Posts 16 Posters 96.6k Views 19 Watching
    • yo-lessY Offline
      yo-less Module Developer @dmcinnes
      @dmcinnes It’s great that you’re experimenting with this in any case. Please let us know the outcome once the sensor has arrived.
      • KirAsh4K Offline
        KirAsh4 Moderator @dmcinnes
        To anyone asking: ‘working voltage’ just means it will work with voltages within that range, so from as low as 3v3 up to 20v.
        A Life? Cool! Where can I download one of those from?
        • yo-lessY Offline
          Alright, everyone. I said I would start experimenting with the PIR sensor and experiment I did.
          So first of all we started drilling a hole of diameter 8mm into one side of a piece of wood
          (we went 5mm deep as this corresponds with the height of the cylindrical sensor):
          This is not all we did, as you can see, we also drilled a hole of diameter 3mm on the other side,
          but this time we made sure it went all the way through:
          Next, we removed the Fresnel lens from the sensor:
          After that, we put the sensor in the bigger hole which perfectly houses the whole cylinder:
          Then we waited to see whether the mirror would turn itself on if we moved past the piece of wood.
          And, hooray, it did!
          Emboldened by this discovery, we started all over again, but this time with smaller holes on the other side,
          so we ended up with this setup:
          Simply ignore the rubber band, it’s there to hold the circuit board in place :)
          Anyway, here’s the good news: The mirror recognizes somebody walking by if the hole is as small as 2 millimeters in diameter.
          It did not work with a 1mm hole, but hey, are we living in a perfect world? :D
          Anyway, this solution is good enough for me, we will drill a 2mm hole in the bottom center area of the mirror frame and hide the sensor behind it.
          I’m thinking we might even be able to make the hole less apparent by choosing a piece of wood similar to the one above
          with some nice-looking wood grain and / or knots.
          1 Reply Last reply Reply Quote 7
            cowboysdude Module Developer
            That is awesome!!! Great job and Thank you for the info!!!
              dmcinnes Module Developer
              I got the microwave radar modules today!
              They work great, even behind my mirror, although they are very sensitive. It triggered on even small arm movements and didn’t require line of sight. Works for my needs though, I just want it to turn off the monitor when nobody is around.
              I haven’t tried powering them with my PI, but they worked fine with an external 5v power supply.
              yo-lessY 1 Reply Last reply Reply Quote 2
                That’s another great way to do it! :) Where did you get them from?
                • yo-lessY Offline
                  @dmcinnes It’s great to hear that they’re working on an external 5v power supply, this means it should be possible to use them on the Pi. It would be really nice if you could try hooking them up to the Pi to see if they’re acting up once attached to the Pi’s pins. I’ll probably try to get one as well if you can confirm they’re working on the Pi as well.
                  • yo-lessY Offline
                    @cowboysdude: You’re welcome :)
                    Also, have a look at this post:
                    dmcinnes said in PIR sensor behind glass?:
                    Another possibility: I ordered a couple of these $2 microwave radar motion detectors to see if they will work behind my glass. Still waiting to receive them though:
                    http://m.ebay.com/itm/1pc-5-8GHZ-Microwave-Radar-Sensor-6-9M-Smart-Switch-for-Home-Control-/131864712562?txnId=1245760396003
                    More details:
                    http://www.cnx-software.com/2016/04/04/tiny-microwave-radar-module-detects-movements-up-to-9-meters-away-for-2/amp/
                      Finally got around to testing on the PI’s 5v power (I’ve busy being sick) and seems to work fine!
                      Next I’m going to hook up to the GPIO and see if I can get the whole thing running together.
                        Now that I have time I’ve finally set up the microwave sensor on my mirror. Works like a charm!
                        The sensor’s data line goes high to 3.3v when it detects motion and stays high for about 30 seconds. It’s set up on one of the 5v outputs. I’ve put some foil around it to help it be a bit more directional since the sensor is so sensitive; I sit under and to the right of my mirror all week and I don’t want it it trigger all the time. It helps somewhat.
                        CatoC 1 Reply Last reply Reply Quote 0
                        • 4 / 7
