    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 125.7k Views 25 Watching
    • BangeeB Offline
      Bangee Module Developer
      so what will I have to do? I’ve removed the MMM-PIR-Module and reinstalled it, but i’ve got still these error… :-(
      strawberry 3.141S 1 Reply Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Bangee
        @Bangee so after the change of the library you still get Error: Module version mismatch. Expected 49, got 48.?
        • BangeeB Offline
          Yes… so I’m quiet pissed off… I think I need to reinstall my MM…
          mm-0 Loading config ...
          mm-0 Loading module helpers ...
          mm-0 No helper found for module: alert.
          mm-0 WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
          mm-0 App threw an error during load
          mm-0 Error: Module version mismatch. Expected 49, got 48.
          mm-0     at Error (native)
          mm-0     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
          mm-0     at Object.Module._extensions..node (module.js:568:18)
          mm-0     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
          mm-0     at Module.load (module.js:458:32)
          mm-0     at tryModuleLoad (module.js:417:12)
          mm-0     at Function.Module._load (module.js:409:3)
          mm-0     at Module.require (module.js:468:17)
          mm-0     at require (internal/module.js:20:19)
          mm-0     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
          mm-0 Whoops! There was an uncaught exception...
          mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          mm-0 Launching application.
            @Bangee did you change your node version at some point?
            • BangeeB Offline
              yes, but this was befor the reinstallation
              so now I try npm rebuild
              • BangeeB Offline
                atm I am using node 5.12.0
                Which node are u using?
                EDIT
                I’ was wrong… I’ve forgot to activate the module in my configuration…
                strawberry 3.141S paviroP 2 Replies Last reply Reply Quote 0
                  @Bangee I’m using 6.4.0 but I got no pir sensor
                  • paviroP Offline
                    paviro Admin @Bangee
                    @Bangee so doesn’t the new version work now?
                    We're all stories in the end. Just make it a good one, eh?
                    – The Doctor
                    • BangeeB Offline
                      Unfortunatly no… :-(
                      I’ve tried many differet versions of of node…
                        McSorley
                        Still a no go for me.
                        • 2 / 9
