    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 132.9k Views 20 Watching
      cowboysdude Module Developer @ianperrin
      @ianperrin That sir is AWESOME! Thank you!
        dr4ke616
        Hey @ianperrin
        Great module by the way. Im messing about with it, and works really well.
        Do you think it would be possible to broadcast a notification to the module(s) that are being shown / hidden so they could react to it?
        So for example if any given module were able to check for SHOW_MODULE, HIDE_MODULE or DIM_MODULE in the notificationReceived function so that the module could react to it and handle some specific behaviour?
        What do you think?
        strawberry 3.141S 1 Reply Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @dr4ke616
          @dr4ke616 hide module will call the hide method of the module
          quote from the readme When a module is hidden (using the module.hide() method), the suspend() method will be called. By subclassing this method you can perform tasks like halting the update timers. so you can do the specific behaviour you want in there
          for show module it’s the resume method
          D 1 Reply Last reply Reply Quote 1
            dr4ke616 @strawberry 3.141
            @strawberry-3.141 I didnt notice this - thanks for pointing it out. Thats exactly what i need!
              plumcraft
              Great idea, i’ve tried your module but i does not work for me. I might have missed a step or something.
              I did put in the config file your module (after download and setup with npm install))) :
                 module: 'MMM-ModuleScheduler'
              And then :
                module: 'MMM-WunderGround',
                position: 'top_right',
                  module_schedule: {from: '0 14 * * *', to: '0 18 * * *' },
                  apikey: 'xxxxxxxxx', // private; don't share!
              				pws: 'pws:IBOULOGN39', //culemborg
              				hourly: '1',
              				fctext: '1',
              				fcdaycount: "5",
              				fcdaystart: "0",
              				hourlyinterval: "3",
              				hourlycount: "2",
              				alerttime: 10000,
              				alerttruncatestring: "french:"
              			classes: 'for_all default'
              It’s 13:30 and the weather is still showing on the mirror.
              Thanks for your help
              Note from admin: Please use Markdown on code snippets for easier reading!
              I 1 Reply Last reply Reply Quote 0
                You’re missing the trigger ;)
                Here do this:
                module: ‘MMM-WunderGround’,
                position: ‘top_right’,
                classes: 'scheduler',
                module_schedule: {from: ‘0 14 * * *’, to: ‘0 18 * * *’ },
                apikey: ‘ad100f1e35ae51d2’, // **private; don’t share!**
                pws: ‘pws:IBOULOGN39’, //culemborg
                hourly: ‘1’,
                fctext: ‘1’,
                fcdaycount: “5”,
                fcdaystart: “0”,
                hourlyinterval: “3”,
                hourlycount: “2”,
                alerttime: 10000,
                alerttruncatestring: “french:”'
                • I Offline
                  ianperrin @plumcraft
                  @plumcraft
                  As @cowboysdude said, you need to configure the classes option to trigger the scheduler.
                  As you already have the classes option set up for what looks like @paviro 's MMM-FacialRecognition module I would suggest trying the following config.
                      apikey: 'ad100f1e35ae51d2', // private; don’t share!
                      pws: 'pas:IBOULOGN39', //culemborg
                      hourly: '1',
                      fctext: '1',
                      fcdaycount: '5',
                      fcdaystart: '0',
                      hourlyinterval: '3',
                      hourlycount: '2',
                      alerttime: 10000,
                      alerttruncatestring: 'french:'
                    classes: 'for_all default scheduler'
                  Please do report back if you are successful because I haven’t tested the compatibility of the two modules :)
                    Opps didn’t realize you were using Facial Recognition… LOL
                    Thanks @ianperrin !!
                      plumcraft
                      @ianperrin @cowboysdude
                      Thank you both, it works with paviro’s MMM-FacialRecognition module.
                        Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
                        • 2 / 9
