    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 123.7k Views 20 Watching
    • I Offline
      ianperrin @cowboysdude
      @cowboysdude said in MMM-ModuleScheduler:
      Awesome module!! The only thing I found it doesn’t work on is the clock…
      The clock doesn’t have a config section and if you add it the config won’t load…
      Can you post an example of your config for the clock with the scheduler options?
      The following works for me to show the clock at 5 past each hour and hide in again at quarter past the hour…
      	module: 'clock',
      	position: 'top_left',
      	classes: 'scheduler',
      		module_schedule: {from: '5 * * * *', to: '15 * * * *'},
        cowboysdude Module Developer
        Well as it turns out… had an issue and had to use my img backup to reinstall the mirror… little did I know I had this already set up and working on the img so it does!!! :)
        I 1 Reply Last reply Reply Quote 0
        • I Offline
          @cowboysdude Glad to hear it works!
            I must have had it setup wrong so that was my fault… like I said it’s working! Thank you!
              Just curious would it be possible not to hide but to dim specific modules?
              strawberry 3.141S I 2 Replies Last reply Reply Quote 0
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                @cowboysdude adding a css filter to the specific module could set the brightness down
                I 1 Reply Last reply Reply Quote 1
                • I Offline
                  ianperrin @strawberry 3.141
                  @strawberry-3.141 said in MMM-ModuleScheduler:
                  Great idea - will give it a go ;)
                  • I Offline
                    I’ve pushed an update which includes the ability to dim a module. Please feel free to update the module and use the example configuration to test it out.
                    cowboysdudeC 1 Reply Last reply Reply Quote 2
                      cowboysdude Module Developer @ianperrin
                      @ianperrin That sir is AWESOME! Thank you!
                        dr4ke616
                        Hey @ianperrin
                        Great module by the way. Im messing about with it, and works really well.
                        Do you think it would be possible to broadcast a notification to the module(s) that are being shown / hidden so they could react to it?
                        So for example if any given module were able to check for SHOW_MODULE, HIDE_MODULE or DIM_MODULE in the notificationReceived function so that the module could react to it and handle some specific behaviour?
                        What do you think?
                        strawberry 3.141S 1 Reply Last reply Reply Quote 0
                        • 8 / 9
