    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 123.0k Views 20 Watching
    • MichMichM Offline
      MichMich Admin
      An other small suggestion: delay all show effects with the a delay equal to the animation time. This way all Modules that will need to hide will nicely hide before any new modules fade in.
      • I Offline
        ianperrin
        @MichMich - some great ideas, keep them coming.
        I’ve created issues (or rather enhancements) for these on GitHub - https://github.com/ianperrin/MMM-ModuleScheduler/issues. Feel free to review, comment etc.
        • Mr.MeeseeksM Offline
          Mr.Meeseeks
          Is it required to restart mm/server if a scheduler configuration is changed, add, removed?
          CAAAAN DOO!👍
          I 1 Reply Last reply Reply Quote 0
          • I Offline
            ianperrin @Mr.Meeseeks
            @Mr.Meeseeks Apologies for missing this one.
            The schedules are set up after the ALL_MODULES_STARTED or DOM_OBJECTS_CREATED notifications have been received from the core. So a restart should not be required and a refresh of the browser should be sufficient to pick up config changes.
              cowboysdude Module Developer
              In retrospect I only wanted to be able to hide a module now and then LOL
              NEVER thought it would turn into such an awesome module!!!
              Thanks @ianperrin !!!
              • MitchfarinoM Offline
                Mitchfarino Module Developer
                @cowboysdude @ianperrin how would would I implement a schedule so that a module appeared for 5 minutes, then disappear and reappear in 5 minutes time?
                I’ve tried this
                module_schedule: { */5 * * * * },
                2nd edit- I thought I’d got it with this…
                module_schedule: { from: '*/2 * * * *', to: '*/3 * * * *'},
                cowboysdudeC I 2 Replies Last reply Reply Quote 0
                  cowboysdude Module Developer @Mitchfarino
                  @Mitchfarino said in MMM-ModuleScheduler:
                  I’ve tried this
                  Yes that should make it run every five minutes…
                  Copy and try this without brackets…
                  '*/5 * * * *'
                  example - schedule: ‘30 9 * * *’,
                  • I Offline
                    ianperrin @Mitchfarino
                    Try this
                    module_schedule: {from: '0/10 * * * *',  to: '5/10 * * * *'},
                    Which should equate to the module being
                    • shown every 10 minutes starting from 0 minutes past the hour, i.e. 0, 10, 20 etc
                    • hidden every 10 minutes starting from 5 minutes past the hour, i.e. 5, 15, 25 etc
                    MitchfarinoM 1 Reply Last reply Reply Quote 1
                      Mitchfarino Module Developer @ianperrin
                      @ianperrin cheers mate!
                      I’ll have a look tonight!
                      Fantastic module by the way
                      • I Offline
                        Thank you and no worries.
                        Unfortunately, I’ve just done a quick test with the expressions I posted above and they didn’t work. :(
                        If you check the cron expressions i suggested using crontab.guru, it would appear they are non-standard. Therefore, I suspect they are not supported by the node cron module.
                        Not to worry, there’s always a solution! crontab.org states that step values can be used in conjunction with ranges. So the expressions I believe you require are as follows:
                        module_schedule: {from: '0-59/10 * * * *',  to: '5-59/10 * * * *'},
                        • 5 / 9
