    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 130.6k Views 20 Watching
      anatius @ianperrin
      @ianperrin
      Hi Ian,
      Below is the relevant output of the log (error log is empty). Note that now (Monday at 3 PM) all modules are dimmed though they should not be…
      MMM-ModuleScheduler received INITIALISE_SCHEDULER
      MMM-ModuleScheduler is setting the config
      MMM-ModuleScheduler is removing all scheduled jobs
      MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
      MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
      MMM-ModuleScheduler is creating a global schedule for all modules using "0 7 * * 1-5" and "0 20 * * 1-5" with dim level 30
      MMM-ModuleScheduler has created the global schedule for all modules
      MMM-ModuleScheduler will next show all modules at Tue Dec 20 2016 07:00:00 GMT+0100 (CET)
      MMM-ModuleScheduler will next dim all modules at Mon Dec 19 2016 20:00:00 GMT+0100 (CET)
      MMM-ModuleScheduler is creating a global schedule for all modules using "0 8 * * 0,6" and "0 20 * * 0,6" with dim level 30
      MMM-ModuleScheduler is dimming all modules
      MMM-ModuleScheduler will next show all modules at Sat Dec 24 2016 08:00:00 GMT+0100 (CET)
      MMM-ModuleScheduler will next dim all modules at Sat Dec 24 2016 20:00:00 GMT+0100 (CET)
      Many thanks for your support!
      Christian
      I 1 Reply Last reply Reply Quote 0
      • I Offline
        ianperrin @anatius
        Hi @anatius (Christian)
        Okay, I think I see the problem, and a fix is in the works, its just going to take a little time until I can finish it.
        I’ve created an issue on github which contains more details on why this is happening.
        Until the fix is in place, you have two (understandably sub-optimal) options
        • leave the mirror running and it should self-correct after the next 8pm and/or 7/8am depending on when it is started :(
        • temporarily use the same expression for all days of the week, e.g.
        global_schedule: [ {from: '0 7 * * *', to: '0 20 * * *', dimLevel: '30'} ]
        A 1 Reply Last reply Reply Quote 1
          anatius @ianperrin
          @ianperrin
          Hi Ian,
          Thanks for the support. You are right indeed, the error corrects itself the first time the scheduler sets the module to undimmed. It is just that the starting conditions are not correct, but this is no big deal for me. It is just that I was too impatient to wait for the scheduler to change status for the first time…
          Christian
          • lucallmonL Offline
            lucallmon
            Firstly, thanks for making such an awesome module!
            However, I can get it to work with all of my modules except one… I can’t get it to work with MMM-Instagram. I have it set up just like all of my other modules, but this one just ignores the scheduler script and always runs, never following the code. Here is the module code in config.js:
            		      	module: 'MMM-Instagram',
            		        position: 'top_right',
            			classes: 'scheduler',
            				module_schedule: [
            					{from: '0 5 * * 1-5', to: '0 9 * * 1-5'},
            					{from: '0 17 * * 1-5', to: '0 22 * * 1-5'},
            					{from: '0 6 * * 6-7', to: '0 24 * * 6-7'}
            		                access_token: '//ACCESS_TOKEN//',
            		                count: 200,
            		                min_timestamp: 0,
            		                animationSpeed: 2500,
                            		updateInterval: 12000
            any thoughts? here’s a picture of what it looks like when the scheduler is active: https://goo.gl/photos/K3S6HA7m61j5iSEe8
            lucallmonL 1 Reply Last reply Reply Quote 0
              lucallmon @lucallmon
              @ianperrin @cowboysdude
              cowboysdudeC 1 Reply Last reply Reply Quote 0
                cowboysdude Module Developer @lucallmon
                @lucallmon Honestly I’m a bit lost on this one… I’m going to defer to @ianperrin for this one…
                  lucallmon
                  alt text
                  https://goo.gl/photos/dFMRL8JkvE5XWvaN7
                  This is what I get when I wake up and the monitor was supposed to go off at night and then turns back on in the morning. This happens every morning. Essentially, the monitor signal cuts but it never actually turns off or enters a low power state as it does when I actually shut down the Pi. This only happens when it’s overnight. When I do a trial off for a few minutes, it doesn’t do it. I think it might be the crappy old monitor, but I don’t know. Any thoughts?
                    I have found that this white screen that happens every day essentially freezes the entire Magic Mirror and I have to press CRTL+Q to restart. It doesn’t actually freeze the entire RPi.
                    • SnilleS Offline
                      Snille Module Developer
                      Hi there!
                      Thank you for this excellent module! :)
                      I would like to use the scheduler together with “Profile Switcher”.
                      Scenario:
                      • Let’s say normally I always show “Clock”, “Monthly calendar” and “Wounderground Weather” (local weather).
                      • Then on Mondays and Wednesdays at 05:30 to 07:30 I would like to also show “Weather” and “weather forecast” (in my case for another location).
                      • Then I would like to have a “profile” called “Snille” who (when activated) shows all of the above plus also “System Status” and “Bitcoin” (for example).
                      I have tried this, but it seams that when a module is scheduled, it get’s “locked” by the scheduler and therefore the “Profile Switcher” can not show it…
                      Getting this in the console (when selecting the profile):
                      Will not show currentweather. LockStrings active: module_0_MMM-ModuleScheduler
                      Will not show weatherforecast. LockStrings active: module_0_MMM-ModuleScheduler
                      If I “force” to unlock (using my Modlulebar to show and hide) the module it can be showed with the “Profile Switcher”.
                      I’m thinking… Do you have to “lock” the modules with the scheduler? :)
                      If you cant find it, make it and share it!
                      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                      • SnilleS Offline
                        @ianperrin I have sent a PR to you adding an option to solve the problem. :)
                        • 7 / 9
