    MMM-Globe
    119 Posts 39 Posters 179.0k Views 40 Watching
      matt25
      Have an issue with the module. Nothing display, only some lines…
      I had a look at the code. The generated URL is correct, when I copy it into a browser I can see the picture:
      http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg?1479826211800
      Then had a look at wrapper and image objects (in getDom) and display their attributes, everything seems ok.
      All other modules works fine on my raspberry. Any help would be welcome, thanks in advance.
      By the way, my config:
          module: 'MMM-Globe',
          position: 'center',
              style: 'geoColor',
              imageSize: 600,
              ownImagePath:'',
              updateInterval: 10*60*1000
      Thank a lot.
      Matt
      Note from admin: Please use Markdown on code snippets for easier reading!
        GinSeng
        @matt25
        Hi Matt, try at position : ‘middle_center’ not only center.
        M Andrius okA 2 Replies Last reply Reply Quote 0
          matt25 @GinSeng
          @GinSeng
          Hi Ginseng, thanks for your help. Already tried different positions but no success:
              position: 'middle_center',
                  style: 'geoColor',
                  imageSize: 600,
                  ownImagePath:'',
          Also tried the module locally on my macbook, but still the same problem… very weird!
          (note that the ‘updateinterval’ is modified when posting the message)
          LukeCodewalkerL 1 Reply Last reply Reply Quote 0
          • LukeCodewalkerL Offline
            LukeCodewalker Module Developer @matt25
            @matt25 Puh. I don’t get what’s going wrong here. Could it be possible that there’s another module is having influence? Maybe you could show us your whole config file.
              matt25 @LukeCodewalker
              @LukeCodewalker
              That’s what I thought… I even removed all the modules but no success!
              Here’s my last config file…
              */* Magic Mirror Config Sample
              * By Michael Teeuw http://michaelteeuw.nl
              * MIT Licensed.
              var config = {
              	port: 8080,
              	language: 'en',
              	timeFormat: 24,
              	units: 'metric',
              	modules: [
              			module: 'alert',
              			module: 'clock',
              			position: 'top_left'
              			module: 'newsfeed',
              			position: 'bottom_bar',
              				feeds: [
              						title: "New York Times",
              						url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
              				showSourceTitle: true,
              				showPublishDate: true
              				style: 'geoColor',
              				imageSize: 200,
              				ownImagePath:'',
              /*************** DO NOT EDIT THE LINE BELOW ***************/
              if (typeof module !== 'undefined') {module.exports = config;}*
              • binderthB Offline
                binderth @LukeCodewalker
                @LukeCodewalker said in MMM-Globe:
                Hey guys,
                here is a module for displaying live pictures of our planet on your mirror.
                The pictures are taken from the Himawari-8 satellite.
                It’s also possible to use custom pictures.
                Thanks! Looks huge on my MagicMirror!
                Did you come across a live pic feed of a different satellite? I’m thinking of one, which has Europe and not Asian Pacific in the center! ;) Would be great to have a switch, so it would show the live shadows of my Position.
                greets,
                Thomas.
                lolobyteL 1 Reply Last reply Reply Quote 0
                • lolobyteL Offline
                  lolobyte @binderth
                  @binderth
                  i replacded the original links in the MMM-Globe.js for the image with this:
                      start: function () {
                              self = this;
                              this.url = '';
                              this.imageUrls = {
                                      'natColor': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBNatColour_LowResolution.jpg',
                                      'geoColor': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_IR108Color_LowResolution.jpg',
                                      'airMass': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBAirmass_LowResolution.jpg',
                                      'fullBand': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_MPE_LowResolution.png'
                              this.hiResImageUrls = {
                  good luck
                  binderthB 2 Replies Last reply Reply Quote 0
                  • binderthB Offline
                    binderth @lolobyte
                    @lolobyte said in MMM-Globe:
                    EUMETSAT_MSG_MPE_LowResolution.png’
                    That’s great! I did this:
                    	self = this;
                    	this.url = '';
                    	this.imageUrls = {
                    		'natColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_natural_color.jpg',
                    		'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg',
                    		'airMass': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_rgb_airmass.jpg',
                    		'fullBand': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/himawari-8_band_03_sector_02.gif',
                    		'europeDiscNat': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBNatColour_LowResolution.jpg',
                    		'europeDiscSnow': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBSolarDay_CentralEurope.jpg'
                    		'natColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_natural_color.jpg',
                    		'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                    		'airMass': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_rgb_airmass.jpg',
                    		'europePartSnow': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBSolarDay_CentralEurope.jpg'
                    	console.log(this.imageUrls[this.config.style]);
                    So, you can choose from more Images.
                    • europeDiscNat: natural Color Europe Picture
                    • europeDiscSnow: snow!!! ;)
                    config.js
                    		position: 'center',
                    			style: 'europeDiscNat',
                    			imageSize: 600,
                    			ownImagePath:'',
                    If I have a bit more time, I’d like to add the standard ones and make a pull request to choose from. There’s a list of (near) real-time images from EUMETSAT: http://oiswww.eumetsat.org/IPPS/html/latestImages.html
                    schlachtkreuzer6S S 2 Replies Last reply Reply Quote 3
                    • binderthB Offline
                      binderth @lolobyte
                      only Problem with these images are the white bottomline, on my MM it looks like this:
                      0_1483012096329_upload-dda9a5c9-d918-4dc6-b35c-ecf790791bed
                      sadly, there’s some white capping down there, but I guess we have to live with that - real time cropping of images won’t make the PIs any faster! ;)
                      lolobyteL schlachtkreuzer6S 2 Replies Last reply Reply Quote 0
                      • lolobyteL Offline
                        lolobyte @binderth
                        @binderth
                        yes, i know. That’s the south pole. ;-))
                        Pull request, good idea.
                        The Images are better then nothing.
                        I searched for a better view for Europe with full disk, but nothing found.
                        Maybe other sources from other user here?
                        • 11
                        • 12
                        • 2 / 12
