    MMM-Globe
    119 Posts 39 Posters 177.6k Views 40 Watching
      Burner911 @LukeCodewalker
      @LukeCodewalker Thank you for helping out! I’m still stumbling along with the code, but if you have time to add the new http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg image this weekend that would be awesome.
      • SvenSommerS Offline
        SvenSommer
        @LukeCodewalker, @Burner911
        I just integrated the ‘centralAmericaDiscNat’ option and made a pull request.
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
        B 1 Reply Last reply Reply Quote 1
          Burner911 @SvenSommer
          @SvenSommer You’re fast! Thank you!
            Renfield
            @LukeCodewalker
            First, thanks for the great module!
            I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
            Is it possible that there’s a caching issue?
            Thanks,
            Renfield
            LukeCodewalkerL 1 Reply Last reply Reply Quote 0
            • LukeCodewalkerL Offline
              LukeCodewalker Module Developer @Renfield
              @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
              B D 2 Replies Last reply Reply Quote 0
                Renfield
                I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
                ?+ new Date().getTime();
                to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
                If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
                Thanks,
                Renfield
                D 1 Reply Last reply Reply Quote -1
                  chrisfoerg @lolobyte
                  @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
                  schlachtkreuzer6S binderthB 2 Replies Last reply Reply Quote 0
                  • schlachtkreuzer6S Offline
                    schlachtkreuzer6 @chrisfoerg
                    @chrisfoerg Niiiiiiiiiice!!!
                    • binderthB Offline
                      binderth @chrisfoerg
                      @chrisfoerg Looks great! but if I understand it correctly, there’s no live-feed at the moment?
                      schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                        schlachtkreuzer6 @binderth
                        @binderth jep, they are testing the stuff and so on
                        • 11
                        • 12
                        • 5 / 12
