@bdream also. let’s try this
stop everything
then
cd ~/MagicMirror npm run server
the server side should start.
@sdetweil said in new update/upgrade script, ready for testing:
space in front of the ./,
That is also not helpful
stop everything
How to stop everything?
Is this enough?pm2 stop 0
npm run server
I get this:
pi@RasPiZeroW:~ $ cd MagicMirror/ pi@RasPiZeroW:~/MagicMirror $ npm run server > [email protected] server /home/pi/MagicMirror > node ./serveronly internal/modules/cjs/loader.js:638 throw err; ^ Error: Cannot find module 'proxy-addr' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) at Function.Module._load (internal/modules/cjs/loader.js:562:25) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17) at Module._compile (internal/modules/cjs/loader.js:778:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) at Module.load (internal/modules/cjs/loader.js:653:32) at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function.Module._load (internal/modules/cjs/loader.js:585:3) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! [email protected] server: `node ./serveronly` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the [email protected] server script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
@bdream I have opened issue
https://github.com/MichMich/MagicMirror/issues/2069I cannot debug more myself at this time. in hospital, sorry
@sdetweil Sam! You are in hospital :face_with_head-bandage:
So you have to focus on yourself!
Wish you all the best and fast recovery!
Hope you are back soon! -
@bdream knee replacement. lots of sitting around and exercising! just not near my computer system
@sdetweil sounds hard to you. far away from your computer.
near time you have to walk and walk all will go as before and better.
All the best! -
@bdream if u rename the mm folder to mm. save and the reinstall does it work?
i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
let me know how it goes
@sdetweil Get well soon!
