    MMM-MyCalendar
    109 Posts 40 Posters 114.8k Views 38 Watching
      A Former User @j.e.f.f
      @j.e.f.f Sorry to keep bothering you, i have everything on the screen now apart from the google calender. Can i embed in as an iframe on the html page? As i am familiar with html.
        j.e.f.f Project Sponsor Module Developer @Guest
        @PCPAYN3 google calendar should work – I’m using two separate google calendars with mine.
        You can confirm that you got your ics link by following these instructions?
        (full instructions here: https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google)
          @j.e.f.f Hi jeff yes thats what ive done and got that link and still not showing. Do i edit the module to show this link? Or in the config file? As i tried to also edit the .js file in the MMM-Calendar module but it said permission denied when saving.
            A Former User
            As I know, private calendar sharing works only in Google Calendar. If you want to use calendar in other application, you should use public calendar. (I might be wrong.)
              I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
              The following error came up in the log:
              Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
              A bit of Googling pointed me to this thread:
              https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
              Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
              /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
              and change the ORDINAL_BASE property on line 56 to an earlier date.
              example, I changed:
              ORDINAL_BASE: new Date(1970, 0, 1),
              to
              ORDINAL_BASE: new Date(1900, 0, 1),
              and then the calendar worked.
              Z B 2 Replies Last reply Reply Quote 3
              • Z Offline
                zzaidi148 @j.e.f.f
                @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
                J C 2 Replies Last reply Reply Quote 1
                  j.e.f.f Project Sponsor Module Developer @zzaidi148
                  @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
                  If so, send me a private message and I’ll troubleshoot your config.
                    bmarofsky @j.e.f.f
                    @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
                    (making sure I remember where I store my backup .img)
                      Buggy
                      Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
                        A Former User @Buggy
                        @Buggy
                        I don’t know why creater leave this issue until now, but there is a hot-fix about that.
                        https://github.com/jclarke0000/MMM-MyCalendar/issues/3
                        B J 2 Replies Last reply Reply Quote 1
                        • 10
                        • 11
                        • 6 / 11
