    274 Posts 78 Posters 725.2k Views 77 Watching
    • K Offline
      kurt @strawberry 3.141
      @strawberry-3.141
      thank you, the icons are here again :slight_smile:
      I’ll try to install pm2 so I can use the New start and Switch off feature.
        pepemujica
        Hi @Jopyth !
        I’m trying to acces from my smartphone, but I have no answer.
        From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
        Kind regards
        strawberry 3.141S 1 Reply Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @pepemujica
          @pepemujica check your whitelist settings
            pepemujica @strawberry 3.141
            @strawberry-3.141 it is empty, with this any IP is allowed to access, am I right?
              @pepemujica should be yes. When you enter from a device which gets blocked through the ipwhitelist you get a message in the logs
              P K 2 Replies Last reply Reply Quote 0
                @strawberry-3.141 Still can’t find the way, the whitelist is empty, I can access from the browser where it is installed the MM, but outside that I can’t, even being at the same wifi network :(
                • K Offline
                  @strawberry-3-141
                  PM2 restart won’t work.
                  Could you have a look, please.
                  Thanks a lot
                  [PM2] PM2 Successfully daemonized
                  Use --update-env to update environment variables
                  │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ watching │
                   Use `pm2 show ` to get more details about an app
                  [PM2][ERROR] Process mm not found
                  { Error: Command failed: pm2 restart mm
                      at ChildProcess.exithandler (child_process.js:218:12)
                      at emitTwo (events.js:106:13)
                      at ChildProcess.emit (events.js:191:7)
                      at maybeClose (internal/child_process.js:877:16)
                      at Socket. (internal/child_process.js:334:11)
                      at emitOne (events.js:96:13)
                      at Socket.emit (events.js:188:7)
                      at Pipe._handle.close [as _onclose] (net.js:493:12) killed: false, code: 1, signal: null, cmd: 'pm2 restart mm' }
                  pi@raspberrypi:~/MagicMirror $
                    strawberry 3.141 Project Sponsor Module Developer @kurt
                    @kurt looks like there is currently no instance running that can be restarted so just start a new one by doing pm2 start mm
                    K 1 Reply Last reply Reply Quote 0
                    • K Offline
                      @strawberry-3.141
                      Thank you, this is what I get…
                      pi@raspberrypi:~/MagicMirror $  pm2 start mm
                      [PM2][ERROR] script not found : /home/pi/MagicMirror/mm
                      pi@raspberrypi:~/MagicMirror $ pm2 show
                        error: missing required argument `id'
                        @kurt [PM2][ERROR] script not found
                        did you follow these steps to create the script? https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                        • 18
                        • 19
                        • 20
                        • 21
                        • 22
                        • 27
                        • 28
                        • 20 / 28
