    274 Posts 78 Posters 714.1k Views 77 Watching
    • K Offline
      kurt @strawberry 3.141
      @strawberry-3.141
      yes I did it following the steps in that wiki
      • yawnsY Offline
        yawns Moderator
        Shouldn’t pm2 start mm be executed in ~ and not in ~/MagicMirror ? The tutorial said to create mm.sh in ~
        So please go back one folder with cd .. or directly with cd ~ and try again
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          kurt @yawns
          @yawns
          this is what I get,
          do you think it is a good idea to start the install routine once again from the beginning? pi@raspberrypi:~ $
          in my modules folder there is no PM2 folder. Should there be one?
          Thanks a lot for help
          kurt
          pi@raspberrypi:~ $ npm start
          npm ERR! Linux 4.4.50-v7+
          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
          npm ERR! node v6.10.0
          npm ERR! npm  v3.10.10
          npm ERR! path /home/pi/package.json
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is most likely not a problem with npm itself
          npm ERR! enoent and is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR! Please include the following file with any support request:
          npm ERR!     /home/pi/npm-debug.log
          pi@raspberrypi:~ $  pm2 start mm
          [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
          [PM2] PM2 Successfully daemonized
          [PM2][ERROR] script not found : /home/pi/mm
          │ Name │ mode │ status │ ↺ │ cpu │ memory │
           Use `pm2 show ` to get more details about an app
          yawnsY 1 Reply Last reply Reply Quote 0
          • yawnsY Offline
            yawns Moderator @kurt
            @kurt
            If you want to start the process with npm start then you have to do that inside ~/MagicMirror
            However if you want to use pm2 then I would advise following the instructions again: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
            pm2 seems to be working fine on your raspberry, so I would start here:
            Make a MagicMirror start script. To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
            cd ~
            nano mm.sh
            Add the following lines:
            cd ~/MagicMirror
            DISPLAY=:0 npm start
            Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
            chmod +x mm.sh
            You are now ready to the MagicMirror using this script using PM2.
            • K Offline
              kurt @yawns
              @yawns
              my first step was to make this start script following the instructions.
              the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
              When I try to start the mm by npm start I get this (the mirror is not appearing):
              { Error: listen EADDRINUSE :::8080
                  at Object.exports._errnoException (util.js:1026:11)
                  at exports._exceptionWithHostPort (util.js:1049:20)
                  at Server._listen2 (net.js:1253:14)
                  at listen (net.js:1289:10)
                  at net.js:1399:9
                  at _combinedTickCallback (internal/process/next_tick.js:77:11)
                  at process._tickCallback (internal/process/next_tick.js:98:9)
                  at Module.runMain (module.js:592:11)
                  at run (bootstrap_node.js:402:7)
                  at startup (bootstrap_node.js:157:9)
                code: 'EADDRINUSE',
                errno: 'EADDRINUSE',
                syscall: 'listen',
                address: '::',
                port: 8080 }
              Thank you
              K 1 Reply Last reply Reply Quote 0
              • yawnsY Offline
                yawns Moderator
                EADDRINUSE means, there is another process running and listening on port 8080
                It looks like the magicmirror somehow is running already.
                • K Offline
                  kurt @kurt
                  @yawns
                  By now the PM2 does its work! Great!
                  When I put the pi away from electricity and then start the pi again, PM2 starts the mirror :slight_smile:
                  But when I make some changes in Edit modulesor Einstellungen, save them, the changes are not shown, also after restarting the mirror but I get Error!also after restarting the mirror.
                  So by now some features work :slight_smile: some still need some time or a little push…
                  Thank you
                    pepemujica
                    Hi @mochman !
                    Is there any chance to change the caption that it is shown of each module?
                    For example, I’ve got 2 clocks modules, so I can see what time is it in 2 different countries. But when I go to the Remote control I see 2 “Clocks” and don’t know which is the clock I’m hiding or showing until I press the boton.
                    Is it possible to change the caption in the control?
                    Kind regards
                      Jopyth Moderator @AAPS
                      Sorry for my long absence. I am currently in the last weeks of writing my master thesis. Therefore unfortunately not much will be happening until second or third week of May.
                      Big thanks to @strawberry-3-141 and @yawns to help everyone out so much. I finally made a release with the outstanding fixes:
                      [1.1.3] - 2017-04-23
                      Added
                      • Portuguese translation
                      • Indonesian translation
                      • Support for iOS Icon and Webapp
                      Changed
                      • Installation no longer needs a temporary file
                      Fixed
                      • Icon paths adapted to changes in Magic Mirror² 2.1.0
                      Hopefully I got everyone covered in my answers:
                      @PatrickGlatz Have you figured it out yet? I don’t think there is any special configuration needed, just need to find the right menu.
                      @kurt Thanks! Hopefully I will come around to improve the config interface at some point, as there are still some known bugs and problems, but I am glad it is already helping.
                      @AAPS You are right, I should probably add npm install after updating MM.
                      @pepemujica What error do you get? Maybe it is something in your network settings?
                      P ? 2 Replies Last reply Reply Quote 1
                        pepemujica @Jopyth
                        @Jopyth Hi! Yes I could solve the part of remote connection, but still can’t find the way to change the name of moddules in the control, since I have for example 3 or 4 iFrames, all of them just says iFrame in the control, so I’m looking the way to customize them. Is it possible?
                        Kind regards
                        • 19
                        • 20
                        • 21
                        • 22
                        • 23
                        • 27
                        • 28
                        • 21 / 28
