    274 Posts 78 Posters 724.5k Views 77 Watching
    • BangeeB Offline
      Bangee Module Developer
      @ceerix can you try this:
      http://192.168.XXX.XXX:8080/remote?action=RESTART
      @Jopyth the pull request is online. :-)
      https://github.com/Bangee44/MMM-Remote-Control
        Jopyth Moderator @ceerix
        @ceerix How are you going to interact? With custom notifications between the modules? Or are you connecting this differently?
        I am asking because I was thinking, if it is possible to give other modules a simple way of hooking up to my module, and how this could happen. So a first example, on how you would like to do it, might be a good starting point.
          ceerix
          @Bangee thank you for your help this works! :)
          @Jopyth i simply call the URL for the action which i want. For example shutdown the Raspberry when i’m leaving the house.
          A example is the link which Bangee have written:
          If you need any further information i will help you :)
          • Mr.MeeseeksM Offline
            Mr.Meeseeks @Bangee
            @Bangee @Jopyth thanks again, this is great!
            CAAAAN DOO!👍
              @ceerix Ok, I see. Thanks!
                Jopyth Moderator
                The module has received a medium update, see the new version on Github.
                Changes:
                • Added: Save as default, which saves the hidden/shown status of your modules (Note: If you change your config, the settings will most likely not load correctly, you might have to change and save them again.)
                • Added: Restart MagicMirror application and switching display on and off, thanks to @Bangee
                • Changed: status indicator appears on top right, instead of the bottom
                • Updated: fixed-width icons, text should be more aligned now
                • Updated: error sign will show (error will appear in server log), if a command fails, e.g. no sudo rights
                • Fixed: style error, which most likely made the remote control look completely different from the preview for anyone except me
                1 Reply Last reply Reply Quote 3
                  d3r
                  New update is sick. Really like the turn display on/off feature.
                    cowboysdude Module Developer
                    Another module that should be in the core :) Man this mirror is growing Thanks to great people!
                    Thanks @Jopyth
                      ceerix
                      I had an idea in the morning. Would it be possible to develop a new menu in this modul for changing the place of a displayed modul? For example moving it from the top to the middle of the screen with a button?
                      Do you understand what i mean? :)
                      J 1 Reply Last reply Reply Quote 1
                      • I Offline
                        ianperrin
                        @Jopyth - another great update. Thanks
                        I’ve added an issue (feature request really) on GitHub to explore whether the functionality of this module could be exposed to other modules so it could be triggered using sendNotification.
                        e.g. sendNotification('REMOTE_ACTION', {query: 'MONITOROFF'}
                        I’ve also drafted a pull request with an idea of how this could be done.
                        If this could be implemented, then things like turning the monitor on and off or restarting MM could be scheduled using a combination of this module and MMM-ModuleScheduler
                        • 27
                        • 28
                        • 3 / 28
